1 - 17 of 17 Posts
HELP!ive got an alfa 155 silverstone 8 valve which has got a faulty vehicle speed sensor and no one stocks this part anymore even alfa,its currently unplugged but the car is fairly horrible to drive with hesitations and poor throttle response
Banned
If you can get the part number,then you can take that part number to mangolesti,or EB spares as it might be the same as 75,164,or check on eBay,you can always find treasure like that on there..hope this helps
i tried mangolesti also,ive only heard of it referred to as the vehicle speed sensor but it sounds like the same thing as you metion,it controls the speedo,mileometer and tells the ecu that the car is moving rather then stationary,i think,anyway thanks for the help because alfa.chris has come through with a used one,hopefully solves the problem
According to ePer , the product is still available :-
46412961 - SENDING UNIT
Availability: - Product orderable
Family: FE27 - TRANSMITTERS
Macro-family: M
Discount code: B
Minimum quantity per package: 1
Unit of measurement: Num
Weight (grams): 100
Listed price: 25.94 GBP
Price including taxes: 30.48 GBP
the speed sensor from alfa.chris arrived today,its fitted and the car is once again driving as an alfa should.Thanks for the advice peeps and thanks alfa.chris for sending it to me,its amazing isnt it that all these parts specialists failed where this forum succeded,big thanks once again
Discussion Starter #14
another thing has reared its ugly head,the speedo isnt working but the car drives properly,the one thing i noticed when i fitted the speed sensor the drive gear that goes into the speed sensor is bent,could this cause the lack of speedo although it was working prior to new speed sensor,confused!
Macro-family: M
Discount code: B
Weight (grams): 100
Celadon, can you give the same info for the 155 2.5 v6 12v 1994? (not widebody)
Thank you in advance
1 - 17 of 17 Posts
