Hey folks got an original alfa stereo and i put the wrong code in and it when i turn on the unit it comes up with this "----" and there is no way to put the code in the, it is a type 932 alpine stereo so help....
no tunes make simon a dull boy
help, thanks in advance
If you put the wrong code in too many times, it locks the unit.
If I remember right from my first Alfa, you have to drive around for a long time with both the ignition and radio switched on (at least an hour I think, could even be more...).
The radio will then unlock itself and give you another chance to enter the code again....
I had to do the same to mine when I bought it. Thought it was around 30mins though (it was 5 years ago). Have you got the right number somewere?
It's a good excuse for a blat out until it clears ;)
Si
(another one).
yep, turn the radio on for an hour (must be with the ignition on, otherwise it will turn itself off), when it is ready the "----" will change to "CODE", you can then enter the correct code.
Discussion Starter · #7 ·
:) :) :) :) :) :) Thanks everyone! had to drive around for and hour and it worked!!!! worth every minute!! thanks everyone again
