Just interested in how you would go about putting one in your car. Like what you would need, where you put it etc
as I said, all depends what you want it for ... there are so many possibilities that it really is not possible to put together a "howto"
see here:
read the forums, MP3Car.com
this is a massive question as it can be done many ways, :) :)
That's a great forum (although I've only stalked on there) ... also digital-car.co.uk forums and forum.centrafuse.com are also pretty good :thumbs:
GTV install
I made a plate to mount a touchscreen and all the switches in the dash:
http://www.rdmfantom.plus.com/GTVimages/CarPC/plate%20rear.JPG
http://www.rdmfantom.plus.com/GTVimages/CarPC/GTVV6.jpg
I bought a car-PC case
http://www.rdmfantom.plus.com/GTVimages/CarPC/PCfront.JPG
installed an EPIA mainboard
http://www.rdmfantom.plus.com/GTVimages/CarPC/PCinternal.JPG
which I mounted on the rear bulk-head
http://www.rdmfantom.plus.com/GTVimages/CarPC/PC%20rear%20in%20situ.JPG
The 12v-12v DC power supply in the case auto-switched with ignition, and auto-hibernates. It also remote switched the pair of stereo amps I mounted in the boot to run sound.
I used Centrafuse for the interface, touch and voice control, plus Directions navigation software. I got a USB DAB radio. USB camera for rear-view. I played with various OBD-II packages.
In the end I uninstalled it and went back to a conventional car stereo as I was fed up of the maintenance issues or the software and the physical install. A fire in the PSU was the final straw.
Hi
Hi there liked the look of your install , just wondering if you had the template for the fascia , want so see if i could get a panel **** on a CNC machine ?
