Hi. Does anybody know how to adjust the default radio volume level, so that the radio permanently starts on a different volume level? Mine is set at 20, but I prefer it close to 30. However, it always reverts back to 20 every time I turn off the ignition.
Administrator
GT 2.0 JTS
I do not have the original radio, but the manual does contain the following. I don't know what this function controls but you can give a try.
EXT function (external audio source control) With this function it is possible to adjust (setting from 0 to 40) or exclude (OFF) external audio sources. To turn this function on/off, use button ÷or˜. The display will show the current status of the function: – “EXT VOL”: function on. – “EXT OFF”: function off. – “EXT 23”: function on with volume level 23.
The standard Alfa radio's always default to startup volume value of 20. This can't be changed....
