Hi all
Just wanted to share my problems with fitting Koni FSD dampers on my GT 3,2. First the decision was to mount original springs with the FSD's as Koni says this is the best solution. Once mounted i had a bit of a shock. The front was suddenly raised about 15 mm compared to the back. Not a pretty sight and not good for the driving pleasure. After measurements was taken, i found out that the springcup on the frontdamper was mounted 13 mm to high compared to oem damper - thus giving the raised front of the car. My first attempt to fix this problem was to lower the car with eibach at the front and keep the original springs in the back. Now the car sits even, but the drivingexperince suffers from the two different types of springs used... understeer, loose backend and so forth. Now i have talked to koni akbout the problem and they gave me the following answer :
"Regarding your comments about this matter:
Just wanted to let you know that this difference is height of the spring seat is a specially made decision made by our engineers. This to improve the poor OE driving quality of the front side of the car itself with the original setting. This to stop the car from getting on “block” which is a well known problem for this Alfa model. As a damper builder, we know that a small difference in ride height of the car won’t effect the driving qualities of the car at all, this is only a visual difference which is only to find out with a measuring rod.
So if we speak about poor engineering you should give your comments thru to Alfa Romeo. They should have done the job right in the first place."
If koni had raised the cups on the back that would be fine. .. but now it's a big problem.
Had any of you guys had the same problem, then please let me know ....
Kind Regards, Jeppe Carlsen
Alfa Romeo GT 3,2
Alfa Romeo GT 3,2
