Multi air unit opens the valves a small amount at part/closed throttle. Shouldn’t affect the compression as compression relies on valves being closed.Was the engine at normal temp ? Shouldn't the figures be nearer to 150psi. Does an MA unit lower the readings ?
I can't see this being a great solution to the problem. It's an oil additive that thickens the oil to reduce blow-by. Might provide a temporary fix but you'll probably destroy the multiair unit which is very sensitive to having the correct oil.Found it on Amazon. Although it’s out of stock 🙄Holts PS4R 100g Piston Seal : Amazon.co.uk: Automotive
Holts PS4R 100g Piston Seal : Amazon.co.uk: Automotiveamzn.eu
found this one on ebay
Worn Piston Rings Blue Smoke Treatment For Classic Car Engine Burning Oil Fix | eBay
It also provides a seal for worn pistons and rings and cushions engine parts to reduce wear and friction. In other words, it’s a car lifesaver in a bottle. Seeing smoke?. We can help. Our Ring Seal Smoke Repair is formulated to help stop blue exhaust smoke, reduce oil burning and prevent plug...www.ebay.co.uk
Yeah. I’ve never used it or know of anyone who has used it before. I was looking for the holts stuff when I came across it. I didn’t really look into it in any detail.I can't see this being a great solution to the problem. It's an oil additive that thickens the oil to reduce blow-by. Might provide a temporary fix but you'll probably destroy the multiair unit which is very sensitive to having the correct oil.
Takes me back to the days when sawdust was a recommended solution to a noisy gearbox...
He would have bought it by the gallon.The sort of thing that Arthur Daley would use.
it can if it's faulty....Was the engine at normal temp ? Shouldn't the figures be nearer to 150psi. Does an MA unit lower the readings ?
It could potentially hold the valves open similar to the old Vauxhall ohc engine ( the followers used to jack up when pressure was taken off them) but it wouldn’t cause oil burning and the engine would misfire.it can if it's faulty....
