If PCV and turbo are new/been checked then it only really leaves external leak, valve seals or ring issue to cause the oil loss
What spec oil are you using in the engine?
Let's try this one more time. May I ask what spec oil is currently in the engine?Got full service at agent. Using the correct specs oil from Alfa agent.
Please explain the spark plug tube gasketsThat might just be oil from the spark plug tube gaskets. Worn valve stem oil seals will give you excess smoke on start up. Idle and overrun conditions. Although because the multi air doesn’t have the same manifold depression as a conventional engine you may not see it at idle.
At the bottom of the spark plug tubes there are rubber gaskets. 55233644 ALFA ROMEO GIULIETTA 1.4 SPARK PLUG SEAL 55233644Please explain the spark plug tube gaskets
Thank u. Will get here locally in RSA at the agent'sAt the bottom of the spark plug tubes there are rubber gaskets. 55233644 ALFA ROMEO GIULIETTA 1.4 SPARK PLUG SEAL 55233644
