1 - 9 of 9 Posts
I have been using Alfa diag alright with previous version but when I downloaded and installed latest version it wouldn't get in to ECU! There are dots at bottom that move up and they came to the end of the line and it didn't connect. I'm using USB type, I checked con fig settings too.
Has anyone had problems connecting?
a timing problem ! fiddle with response times in the connect menu
I have a private Alfa airbag reset company here in Holland (lol) and sometimes Alfadiag takes some time to handshake with the ECU , I have done some 32 cars (mostly 156's) and they all behave differently.. I have no explanation for it, but the result counts !
p.s. I had guys who paid 3 times at the dealer for a reset ! 30 ukp per reset .... would you believe it !!!
ECU resp timeout (ms) 1000
Resp Interbyte timeout (ms) 50
KWP/ISO
Anything more to review?
Thank you!
Another question....
is there only one OBDII slot to connect? I thing i have connected in the correct slot but i haven´t find any picture where it shows where to connect it.
When i connect the OBDII interface a led turns in so i think that´s is correct.
Must I start the engine to get connected to the ECU? I have only try with the key in MAR position.
1 - 9 of 9 Posts
