1 - 10 of 10 Posts
Hi there,
Is anyone here in the Woking/Guildford Surrey area that has alfadiag?
If so would they be willing to run a test on my v6 for me? i will make it worth their while
cheers
Whats it worth, according to your signature you work for McLaren - i'll do it for an F1 car.
Seriously i'm in North West London, if there is no one closer them maybe we could sort something out.
I have AlfaDiag and a cable that I use for my 147, so long as the ports on the car are the same (someone please confirm) then we are good.
What problems/symptoms are you experiencing?
intermittent cutting out in all conditions, can't find a pattern you see.
Had cat and lambda checked and all good, new maf also and several reset's, plus a throttle body clean up
was hoping to find someone a little closer really, but we'll see eh
cheers
Banned
Change the crank sensor, it's an easy fix, it's mounted by 2 of the sump bolts and reads the back off the flywheel. The wire runs up the front of the gearbox.
im in pompy if thats any good got cable for 156 and after 6 mounths of trying to get alfadiag to work new drivers and hay presto it works lets us know if you want help
... and I'm in Camberley ...
Think i've found a air leak in the intake flexi which could be the problem. Will come and see you some time if i may 156 chris if this does'nt solve it
cheers
cheers
Yep not a problem :thumbs:
I'm in Rijswijk The Netherlands, if you pay the travel expenses....:cheese: I am your man (may even take the Examiner kit with me)
1 - 10 of 10 Posts
