Hi guys,
I recently got my fiatecuscaner to work with my PC which I'm very pleased about. However, I was hoping for some than just checking codes. In VW/BMW I was able to code comfort module to eg. close windows when I pressed close button on fob, or even enable small perks such as parking lights when I leave indicator on and switch car off.
Is this possible with alfa romeo? I couldn't find any posts dedicated to this topic.
Thanks,
Luke
L
FES can code the remote control function for a 147 but not the 156. otherwise i guess nothing can be done like you described.
So just to be clear:
What CAN be done?
- Checking error codes from ECU/Airbags
- Running some simple tests (at least on FES)
:confused:
L
errors on Engine, Airbag 7 ABS ecu can be cheakced & cleared, + diagnostics of engine & BOSCH 5.7 ecu
D
Other way round I think - but you will need the correct code from alfa unless it came with car :)
