Is it possible to adjust the camber and the alinment of the back wheel my bolts are oxidated does somebody know?
I'm no mechanical expert, but as an owner...
There are adjusters for the rear toe in/out, but they become seized to the point where mechanics will say they are unfreeable unless treated with the right grease reasonably regularly. You can get a new pattern part from Alfaholics, but they won't fit unless you grind down the bushes. Autolusso supplied me with a used set that did the job perfectly.
Rear camber is not adjustable unless you cut a slot in one of the top suspension joints. Powerflexing made my camber extreme, but I thought better to put up with that and the uneven tyre wear rather than start bodging in the suspension...and it does no harm to the handling.
