1 - 12 of 12 Posts
Hi All,
I have a 1991 Alfa 33. Its a 1.7 IE.
Great little car, what can i do to increase horsepower ?
Any ideas would be great!
Although the increased power will occur higher up the rev range and you may miss the lower down torque of your IE engine.
- Dual throttle bodies
- Injectors with higher flow rate
- Get rid of the flap-type AFM (and the LE3 Jetronic injection)
- Low restriction air filter
- Ignition conversion to distributorless
- Wet nitrous set
Turbo!
Either remove catalyst or use one with more free flow. You will gain up to 6hp as catalyst really killed the engine.
Most NZ cars didn't have a cat. Unlike Aus spec ones which even for series 1 33 had a crude EGR system with pipes coming off the manifold either side of the gearbox up to the airbox. Crazy.
1 - 12 of 12 Posts
