Hi, My 2.0 GTV JTS (2004 model) ate a piston. As the con rod flapped around on run down it has dented the cylinder bores.
Please could I get advice on where I could get hold of a replacement block. I have checked e-bay and can buy a whole 2.0 ts for around £250, but dont need the ancillaries and head just block, ideally with crank and good bottom end bearings.
Derby based, can pick up from anywhere not too distant.
Cheers,
Sam
· Registered
Try Autolusso in Houghton Regis, Bedfordshire ( Close to M1 J12 or J11 ) - fairly easy from Derby!
EDIT : I'd budget on sticking in new bearings anyway whilst the engine is out. It may have had a timing belt failure so better change them and have peace of mind.
Hi, JA5ON, Iam interested in your spare block, do you have a price in mind? and is the block accesible to be crained into a small trailer
(can't beliveve how heavy they are with flywheel and other bits on)
cheers
Sam
