ok guys I have a nasty update as I checked the voltage at the injectors today and I am more confused so
ulled all injectors plugs and measured the left and right pins with earth to the head and body here it is: WITH IGNITION ONLY:left pin 0,90v to head and -12,50v to positive + <battery> ,,,right pin0,02v to head and 0,00 to positive WHEN CRANKING:LEFT PIN 0 TO 2,40V ON THE HEAD FLUCTUATING,,,RIGHT PIN 0 TO 2,40V TO HEAD FLUCTUATING should I not get + 12v on ignition to the head as the common wire always supplies that and you earth the voltmeter to head or body??? I only get -12v to left pin when I earth it to the actual positive wich means that on the common wire travel negative <earth> instead of clean +12v? please somebody with electrical experience or having same sort of trouble take this in consideration AFTER ALL THAT WHY WE ARE THE ALFA ROMEO SOCIETY ,TO SHARE TROUBLE AND HELP IFF POSSIBLE ,THANKS IN ADVANCE
You have to determine which is the common injectors wire first.
To do this:
1 - Disconnect the battery
2 - Disconnect all the injector plugs
3 - With a multimeter (in ohmmeter mode) measure the resistance between the injector wires of 2 different injectors.
Suppose that the injector wires are marked as: 1a, 1b (the wires of the first injector).....2a,2b the wires of the second one..........etc.
When measuring this resistance, try all of the possible combinations: 1a - 2a; 1a - 2b; 1b - 2a; 1b - 2b.
Doing this, you will get a resistance very close to 0 ohms in only one of the four possible combinations.
Suppose that this combination is 1a - 2a. - that mean - the common wire for injector 1 and 2 is this one (1a for injector 1 and 2a for injector 2)
It is not necessary to do other measurements, because you already found which is the common wire.
4 - plug back the injectors connectors
5 - attach the battery
6 - put the multimeter to voltmeter mode and connect the black lead to chassis
7 - connect the red lead to the injectors common wire and crank the engine
You should get +12V in this situation.
Tell us the result.
BTW - according to the documentation, the common wire should be attached to pin 1 of the injector connector, as shown
here.
So you can skip points 1 - 5 and jump directly to point 6
PS:
I'm not sure that i've been clear enough because of my language skills
