Hello all, last night a couple of minutes after coming off the highway (constant 100-120kms for an hour), when i took off from a set of traffic lights the engine light came on and the car would not go over 2000rpm. All gauges are fine (temp and oil pressure) and there was no warning signs that i could tell of something was wrong. It felt like i was running out of fuel as i took off. I limped back home (12kms in 50kms streets) by manually shifting up the auto gearbox as they hit 2000rpm. The car was smooth and the gearbox normal. This morning i started the car and same thing with the car cold. I tried disconnecting the battery for a few minutes but no change. I have ordered an OBD2 dongle but my question is, do you think i can risk driving it to a workshop that is 20km away without knowing the error codes? The car seems to run ok in the low range so will have to avoid the highway. My suspicions lie with the fuel system but I am quite new to these cars. My last tank I had to fill up at a no-name petrol station on the highway that only had 95 RON and i was about 3/4 of the way through that tank. I usually run V-Power. Any thoughts?
