1 - 20 of 94 Posts
Just glad to spread the knowledge :thumbs:
Just for information ... they are ".rar" files so you'll need something like WinRar to extract them, inside them are ".nrg" which is a nero cd-image format, so you'll need nero to burn them (although I believe that other programs can extra the content ...)
hi, i downloaded the elearn for the 147......how can i make it work....no .nrg file!!:confused:
I've only downloaded the 156 versions ... what files are present in yours?
ok then I'll download it and see what I can do ...
Right ... inside the .rar file for the 147 eLearn is a .iso file, this is a disk image file, as this is a standard file format disk compression tools (such as winrar) can open it and look at/extract the files ... which I think is what you've done. What you need to do is burn this .iso file as a disk image (note this is different to burning it as a file on the disk), or alternatively (and preferably) use a disk image program (just as nero image drive) to mount the image to make it look as if it an actual CD ...
good luck!!!
Thanks man (156Chris)! Your the best!
:lol:
Alfa Mito, 2010, 1.4NA, 6-speed
It's the Workshop Manual ... how to take it apart and put it back together without any bolts or screws left over. ;)
EPER is the parts system (DVD based) and DTE is the older version of elearn.
Similar to the Haynes manual but runs on a computer .. not a book. Haynes will not produce a manual as they say there is "insufficient demand"!
thanks alot, just in the process of downloading it atm,
hopefully this should help me piece all the little things on my alfa together..
i used the workshop manual on my fto, n believe it was a god send, so im hoping to have the same kind of luck with my 156.
thanks
1 - 20 of 94 Posts
