1 - 10 of 10 Posts
It might just need bleeding but more likely could be a burst slave cylinder. The not turning over sounds like a flat battery.
Or if it is jammed in gear and the clutch cylinder has failed, you'll be trying to start it in gear, which in the current weather could well stop it turning......
I agree that you should be able to get it out of gear with a little "gentle" persuasion....the see if it'll start. But I reckon you'll need a new slave cylinder - at least on the V6 its an easy job.:)
iv tryed rocking it no luck iv tryed to pull it out of gear with gear stick wont come out well and truely stuck i do think is the selecter pin but need right weather to carry on with it thank u every1 who has replyed
1 - 10 of 10 Posts
