hi guys
i am hoping someone out there the know could help me out of a spot of bother
i have just bought a 156 2.0 twinspark with a broken timing belt
i have done the job of replacing all the bent valves and rebuilding
when i turned the key and the fuel had pulled through it fired up
and ticked over (a bit lumpy) but it will not rev when i press the
accel it jusy died
any idear please
L
year of car?
try disconnecting the air flow meter, located between the battery & the engine.
if its cable accelerator is the cable connected on the throttle body?
if fly by wire, is that connector on the throttle body?
any error lights on beside the No:8 of the rev counter?
any error codes read from ecu?
hi there
just had a new air flow meter before i bought it
accel is connected ok
will go check for error codes
and report back
cheers
hi there
and report back
cheers
But was it the right one? And was it new?
MAF doesn't always show codes unless it's really dead.
