1 - 2 of 2 Posts
Ok so my antiroll bar bushes are worn out on my 156 Alfa and was wondering what bushes i should buy and if there are any guides on replacing them. Hoping to only replace the bushes to save me some cash as the shipping on the whole set would be way too much.
Should i go all the way to Powerflex bushes or is that just a waste of money ?
Any bushes you guys recommend ?
Powerflex bushes are ok. Measure the diameter of the bar as they vary.
The bush mounts will need to be split as they weren't designed to simply replace the bushes.
Give the mounting bolts a good soak in proper penetrating fluid .. And repeat it a couple of times as they probably have been off. You might want to replace the droplinks too. Check out Meyle's heavy duty ones.
1 - 2 of 2 Posts
