is the outer door handle on the drivers door easy to replace, as mine is playing up the button keeps sticking in have tried lubricating with both WD-40 and Silicone Spray to no avail, it looks as though it's rubbing on the sides as there are scratch marks on the side
Poke something thin & flexible through the gap while spraying with lube and it will washout the dirt causing it to stick.
ok, shall try that, although it's just decided to pee it down now so might have to wait a while
I've tried WD40 and silicone spray. I've just had a go with Mr Sheen which has a bit more body to it. We shall see.
I used 3in1 and worked the button in and out for a bit. Fixed the sticking but every time it rained I got a lovely mess down the side of the door it did stop after a while and the button still worked so I felt it was worth the mess for a while.
Same problem here. tried wd-40 but thinking trying pencil lead around side as thats what i do with sticky keys, lubs it without the mess. Will post back later.
