anyone know any other cars that have the same bolt pattern as the 156,i cant seem to find another car with the same?
5x 98 pcd 58.1 bore and 35 to 42mm offset:thumbs:
There isn't one... Fiat 5x stud and Lancia 5x stud but very very rare indeed.
Most peeps go for 100pcd with wobble bolts and get the plastic spiggot rings to fit Alfa 58.1 bore
The good news is: the ET offset is quite common though
They use a 5x98mm PCD and no other make uses that.
You can use 5x100mm PCD wheels with wobbly-bolts be the centre-bore MUST be correct.
From Alfa, the 156/147/GT/GTV/Spider all have the correct PCD & centre-bore but only the 156/147 share exactly the same offset although the others will fit fine with wider track.
I've some 1000 Miglia 17" wheels with stretched tyres (loads of tread) that came off my 156. Looked the dogs and fit very well! Let me know if you're looking for wheels like that as they're surplus to requirements! :)
