· Registered
Hi everyone. I was stuck in traffic the other day, and my engine started to overheat. It turns out that the fan wasn't working. I tried running a wire from pin 86 of the relay to earth, and the fan didn't come on.
However, since doing that, the engine won't fire. All electrics seem to be working fine.
Any ideas guys?
· Registered
First of all, you can't trust the markings on the relay cover.
Which relay did you do that to and is the wiring back to normal now?
· Registered
only thing i can think of is there might be something wrong with the CODE system. it probably isnt but worth a go checking. when you put the key at MAR a yellowish light with a key symbol and the word CODE under it should light up for 2 seconds or so then dissapear. this light is in the bottom right of the check panel. my car used to have all electrics working but the engine wouldnt start and it turned out to be this. sorry i cant give you much other help
