·OK first the good news, I have just driven a 156 2.5V6 manual with sports pack and 16inch wheels and 205/55/16 tyres, it came in today for some work and I just happened to claim it so I could test drive it for your fault. The vehicle had done 24000 miles and had no apparent wear in the suspension or steering. I tried it accelerating, on over run and braking and it drove dead straight in all cases. It did drift down the camber of the road but was as any other car would be, (I drive about 2500 cars a year). I tried it on my normal "camber" test route and with no camber the vehicle was perfect. The fact that you said earlier that you can drive on the wrong side of the road and it will go UP the camber means the car is NOT camber conscious.
The bad news is that this means you DEFINATELY have a problem and you need to take it back to the dealer. Unfortunately I don't expect you to get very far as it doesn't sound like they can cure it for you. By the way the front wheel geometry was changed last year, I haven't found out why yet but the settings are now 0+/-1 mm or parrallel +/- 1mm. They were toe out 2.07mm +/-1mm, now from my racing experience toe out causes oversteer and may possibly cause this pull. I will speak to Alfa tommorrow regarding this and will post back anything I am allowed to release.
By the way could you email your chassis number so I can check the data.
