61 - 80 of 114 Posts
· Registered
Progress
Also I put a breather filter on rather than reconnecting it
Hey Chris,
i had this done myself but found the Turbo spool was worse than before - as on the 8V the Oil Line is connected to the intake just right before the turbo i suppose the additional Pressure of it helps spooling the turbo - after i reconnected it the Turbo spooled about 400RPM sooner.
best regards,
PS: are you planning to keep the fog lights?
· Premium Member
I've put my breather filter directly on the oil separator as well (as 16v and 20v have a separate one). But this still makes a big mess of the enginebay. Im thinking of putting a pice of tube on it so the breather filter will be on the bottom of the car and wil only spoil a little oil on the road instead of onto the engineblock
· Registered
Discussion Starter · #63 ·
Hey Chris,
best regards,
I've found that the spool is signficantly quicker than before, it flicks up into the overboost region in no time at all
· Premium Member
For the oil breather, personally I don't see what is wrong with the OEM recirculation system.
@Chris: you have placed the MAF in a very low position now, aren't you afraid it gets too much moist inside?
For the rest, looking nice, do you still have the foglights ?
· Registered
Mucking intake with oil and fooling metered air flow
· Premium Member
I have positioned my maf low as well. It gave me some trouble during heavy rain.
Since my undertray is back on, I've never had any trouble anymore
· Vendor
How much oil are we talking about? One droplet every 1000 km or so?
Basically it's oil vapour since the heavier particals condensate inside the valve cover.
And because the vapour is sucked in after the MAF, I don't see an issue there too.
The less oil into the intake the better though, I have seen how oily they get in there from crankcase breathers & leaky turbo oil seal, mix that with the EGR soot and you have a recipe for disaster.
· Registered
Discussion Starter · #71 ·
What difference will it make if it's MAP driven instead of MAF?
The ecu will use the temperature of the air in the manifold to determine how much fuel to put in, rather than just guessing it from the maf values
· Registered
nope, it doesn't do any magic related to HP
· Registered
Discussion Starter · #75 ·
looks very impressive chris :)
im looking to do the same with the intercooler, but can i ask what are the dimensions of it ?
not too worried about pipe work, as a friend of mine will have a good idea of dimensions
here you go
Bar and Plate Intercooler Corn size: 550mm x 175mm x 64mm, Overall length: 690mm
2.25" (57mm) Inlet and Outlet
Maximum Pressure: 45psi
Max Horsepower Capacity : 450hp
· Registered
Discussion Starter · #77 ·
· Registered
Exactly that one (from that seller!!!) although I bought the pipe kit and the intercooler seperately because I wanted black silicone!!!, the one I bought was actually advertised for a Vauxhall Nova :confused:
so was all that piping used on your setup ? or did you have to buy extra piping ?
just curious is all, as it will be pretty easy to go on by your photos.
· Registered
Discussion Starter · #79 ·
In addition to that kit I bought a 57mm - 51mm 90deg silicone reducer for attaching to the turbo, plus a 57mm - 51mm 45 deg silicone reducer for attaching to the engine intake (although the 51mm is a bit tight but fits ok).
For the air filter I bought a 60mm-70mm 45 deg silicone reducer, and a small length of 70mm ali pipe.
I have had a few problems with "blow off" from the kit as the pipe work does not have any beading, I've fashioned a bead making tool which I will be showing when I get round to using it (got far too much other stuff going on at the moment!!!!)
· Registered
Discussion Starter · #80 ·
Beading!!!
Well here's my DIY beading tool!!!
and the results ... which I think are good enough
