Hello!
A past few weeks I have been doing some work on my Alfa. Changed the spark plugs, cleaned the throttle body, "taped" the air intake after the MAF, etc.
The engine was very rough before the change of spark plugs and I thought that will make things better, it did but now i have misfire in the rev range 900 - 2000 and the idle is rough. https://www.youtube.com/watch?v=zjf7zqXPjfE I found this video and it sounds just like mine! Sprayed WD40 over intake manifold with no change in idling, thought that there are air leaks. The only change for better is when I take the air filter off of the MAF and make the intake hole on the MAF smaller with my hands thinking that there is to much air going into the engine if there is an air leak. But also thought that maybe MAF is bad. Can you help me with this, maybe somebody had a similar problem? The diagnostics doesn't show any errors. Thank you!
