Hello,
Having trouble with my 147 Selespeed, i purchased the car not going ( won't crank and the neutral light is flashing), i found some blown fuses and a few bad connections here and there but still no luck, i can get the car to run by bridging the starter motor but still won't select gears and the neutral light remains flashing. There are no trouble codes in the selespeed system and i have run a calibration with a Snap on scan tool with no luck, i can also individually check the clutch , servos etc and all seem to work fine, the only thing that appears on the scan tool when i go through the data is i can see 'engine start up' and next to that it says 'not allowed', i know the key is fine and there are no trouble codes in any of the systems, and the brake light switch is new. My next step is to find a good auto electrician but just thought i would put it out there first, thanks
