Can a bad Variator or variator solenoid causes an engine to misfire when idling
Sent from my AMN-LX9 using Tapatalk
2004 Alfa Romeo 156 1.8TS
No, that would more likely be down to:
  • Worn camshaft
  • Stuck valve lifter
  • Burnt valve
  • Worn spark plugs
  • Worn coil pack
  • Worn injector
Have you done a code check on the car?
Ok any idea where the Idle Air Control valve of 147 alfa 1.6 is located
