Greetings guys,
Recently I've become an owner of 5-door Alfa Romeo 147 1.6 TS. Moments ago, I've wanted to change some broken bulbs. I've disconnected the minus terminal from the battery and changed the bulbs properly without any trouble. I've connected the battery (minus cable) back and started the engine. All bulbs now work great and the rest of the electronics are fine, BUT, total kilometers counter is reseted to 6 lines ?!? Odometar and clock were also reseted, but I've set the clock without any trouble, and odometer noted the 12km that I've drove from my friends garage but the total km still shows the 6 lines (minus signs) instead of any numbers...
Any ideas?
Thanks,
Ilija
usually it signifies a problem with the memory chip (or a roll-over from maximum mileage) .....
You could try a proxy alignment, but if that doesn't work, it could mean it needs to be repaired ....:(
