1 - 2 of 2 Posts
Does anyone know how to take the rear plastics off the inner tailgate on the 04' 147 lusso? Firstly the boot stopped popping so i need to get under the plastics to change the motor but after removing all the screws/bolts it still won't budge. But dont want to push it too hard incase its just plastic clips on the back that i'll snap! Any help?
Do a search, there are some photos somewhere. Assume you've removed 4 screws, 2 at the side and 2 in the "handgrips"?
I removed mine again at the w/e as the blasted washer pipe came out again, glued it in this time!
As for removing the trim start at the base/edge of the tailgate, some use a thin piece of wodd or screwdriver blade. Once you know where the clips are it's easier to prise them off. However take care, the trim is notoriously fragile!
1 - 2 of 2 Posts
