1 - 1 of 1 Posts
may help a few people out, the biggest problem is the cheap Chinese 327 cables, to access the CANBUS system needs a certain frequency to connect, theres a few guides on Multiecuscan forum on how to get around this fault. you will need to open up the cable to access the board where you will need to remove the 120ohm resistor restricting it from connecting, its usually labelled R04, this will need to be removed and hopefully this should solve any problems youve come across.
so it can be done, after abit of research it soon pays off.
1 - 1 of 1 Posts
