1 - 9 of 9 Posts
Someone will have to answer the technical question. Certainly PCD etc is exactly correct but you may need 10mm spacers. However, I can definitely say they look great on the GTV or Spider. Go for it!
There are a few GTV's with the GTA wheels and I'm sure one of those guys can give you a definitive answer.
The offset of GTA wheels is 35mm compared to the standard GTV which is 30.5mm so the GTA wheels are 4.5mm further in but I would think they will go on without problem. You could space out the wheels a bit if you wanted but I cant see 4.5mm making too much difference as the GTA wheels already clear the GTA Brembos.
You might need to check the wheel bolt length too
I've fitted the GTA wheels on mine. They do go straight on but you will need shorter wheel bolts and they do get very close to the calipers and rear spring pan arms. I would recommend 10mm spacers that way you can use your old bolt. But make sure they are hubcentric, otherwise you will get wheel wobble.
And yes they look fantasic.
1 - 9 of 9 Posts
