1 - 11 of 11 Posts
Hi all
I have a set of 147 GTA spings in my garage but I drive a 147 2.0 does anyone know if the GTA springs wil fit ? And will it lower the car ? And ride hard or soft ? Cause rear of car dips heavy on pulloff .
Thank
Giulio
They will fit, but the front spring rate will be too high for the lighter 2.0TS engine.
Given the very high ride height of a std 147 it may not change the front hight much, but the rear will be lower, but as I said, the front spring rate will be wrong.
Thank for the reply.
What would the higher spring rate do to the car ? Will it have a harder ride? I know someone who can mod the spring for ride hight . But only the front will need to be modified for hight?
Thank
Add ballast to the engine bay :lol:
Discussion Starter #7 (Edited)
Thanks David C
I think it will be best get a set of koni springs 35mm to be on the safe side .
And as for the other two they must put a ballast in there pants hahahaha!
Glad you took the comments in the way they were intended :thumbs:
*need a laugh in the tech lounges now & again :D *
L
its as easy/hard to fit the right parts as the wrong parts
alot of people swear by Eibach lowering springs [ progressive type ]
Thanks David C
Hey Giulio, see you based in Gauteng - have you visited the South-Africa forum? Ask your serious model related questions in the model related forums, but come check out the local knowledge:
South Africa - Alfa Romeo Forum
Come introduce yourself in: http://www.alfaowner.com/Forum/south-africa/191168-whos-who-in-the-alfa-zoo.html
I am also hunting for new suspension parts - thinking coil-overs...
1 - 11 of 11 Posts
