1 - 1 of 1 Posts
hi, i have an alfa 147 tspark 1.6 2002, when the car is jacked up at the front on both side and you put the car into gear and foot on accelerator, the wheels sometimes stop and start and the engine makes a clunking/rumbling noise and shakes like mad. just got timing belt, variator, rocket cover, drivers side drive shaft, front wishbones changed within the last week have had it a three garages so far When driving there was a clunking noise when changing gears and slowly putting your foot on accelerator, also when at top speed the car started to shudder and noise got louder and gear stick shook. Only got drive shaft done today and noise seems to be gone when driving, the noise is now only when car jacked up. wasnt sure if it could also be a problem with the differential. also when car is reversing up hills it makes a dragging noise, as if you still have handbrake on. also clutch is very heavy. ?? ?????????? thank you any advice would be really appreciated
1 - 1 of 1 Posts
