1 - 9 of 9 Posts
Hi everyone. I hope someone can help me. Every time i put the car into reverse it blows the 7.5 fuse which results in the reverse light not working and the lights on the climate control dials. I have changed the reverse bulb, the reverse light cluster and the reverse switch sensor on the gearbox! Any ideas????
Thanks Kevin
M
Got the same issue....
First places to check for a short are... In the rubber protection from body to bootlid as wires often break here. Then I would check the little wires that come out of loom and run to reverse sensor on gearbox.
If all that is ok a faulty reverse sensor can short to earth. So pop car in reverse gear (no need to be on) and check the pins with a volt meter for continuity to earth. If both pins on sensor show continuity to earth then sensor is at fault.
If it's none of the above then your looking for a short somewhere in the wires. In my 156 I am going to investigate if I can split the look anywhere so I can test at least which part of car short is one (even if just front to rear or between engine and car).
John
I'm guessing you've already checked the rear light cluster wiring isn't being trapped and shorting against the bodywork when you replace the cluster ? This is the problem I found, the wiring not being easy to see when you stuff everything back together.
Are you replacing the fuse with the same ampage?
Try a larger fuse 10 or 12.5 maximum if it still blows then you have a body contact/ bad earth issue
If it works like it should with a slightly larger fuse in and doesn't blow, then you have a slight over current to that line usually a bad earth too.
I had an issue that was similar on a ford, it would constantly blow the fuse for the sidelights... Did the above and it worked fine after that, I never found the fault but a couple of weeks later I replaced the fuse with the correct value and it didn't blow????? It fixed itself!:rolleyes:
Try and figure that one out?
M
on 156 it's a 10 amp switched live...
Tried a 15 just to see but as soon as you put it in reverse pop...
So defo a short, just to find out where or if it's the sensor thats duff :)
Thanks guys i will try your suggestions, however i did up the fuse from a 7.5 to a 10 and 15 and they both blew straight away so it does sound like a short to earth. Will keep you updated. Thanks again
Refrain from putting a higher value fuse than stated. Risk of causing damage to the body computer.
1 - 9 of 9 Posts
