1 - 13 of 13 Posts
Hi guys,
Where do you recommend me getting a cold induction kit for my alfa 1.6 2003?
I see Auto Parts, Engine Parts & Car Accessories | Masterparts lists for the 2.0, and k&n website lists it for the 2.0 and 1.6
Any recommendations where I could get one?
As some of you might know, i recently had a front accident, and i only recently found that my air box is slightly cracked.
So i was thinking, while I am at it, why not an induction kit for the sound and extra ooomph (although not really any ooomph).
Thanks.
Careful kyle, all you are going to be doing is fitting a large suction for water in the front of your car...
Did you ever find that bonnet by the way?
Yes, i got one for R500 :) with very minor damage that I can fix myself, i must just pick it up.
Georgio has an original air box for me, just want to see what is recommended by the others :D
Who did you rob for the bonnet :wow:
Haha it has a dent on the side of the bonnet, but the crumple zones are still fine. I can fix the dent part and make it straight myself but still going to go to willson once I have everything together for painting.
Might be a month from now tho. Things are going slowly as the days are warming up, using the bike :).
Anyways, if anyone can comment if they have put a k&n induction kit on theirs? Or is it better to get an original air box and then get a k&n filter?
Going to have to wait for the guys replies then. My main concern is the 1st lot of heavy rain you get and then you bend a rod by sucking up 15mm of water....
The standard panel is big enough for 1.6 Airflow - release the bit of restriction by fitting the K&N panel :thumbs: That is guaranteed slightly better than OEM - induction kits have proved to loose power in many cases...
Discussion Starter · #8 ·
Thanks, not sure what you mean by K&N panel? Have heard of the K&N Air Filter for 1.6ts?
Try accessories stores like Autostyle etc. Years ago I bought a K and N panel filter for the 145 from Racers Edge.
Also try ATS Motorsport. Go for the K&N flat panel replacement filter. The induction kits sound nice, but tend to lose power because they inhale hot air, unless you build a cool enclosure as well.
1 - 13 of 13 Posts
