sorry guys but i have to ask ,can you change the alarm pickup in the rear light
without changing keys as well as i have done the bonnet switch test and everything seems ok
its just when i try and enter code to unit via the little dimple switch it just stays light my car is 1996
16valver and is starting to **** me off now it did work but stopped i can only asume the reciever
is at fault any help appreciated.
fletch, i've had problems with my alarm in the past, it turned out to be the multi-plug behind the left headlight. it was corroded so bad i had to cut and solder the wire joints.
i too had this prob and did renew with terminal blocks thanks anyway the the reply it did work after i done this but no longer does.
