Hi all
Is it me, or is the factory fit alarm/immobiliser require that you stand right next to the window to operate the central locking and arm/disarm the alarm.
Has anyone else experienced the same problem?
Can you use your keyfob from at least 6 foot away?
any help appreciated
LesPix
2.0 TS 16v 1995 :(
HI LESPIX, FIRST OF ALL CHECK THE 2 BATTERY
IN THE KEY AND AFTER THIS CHECK THE WIRES CONTACTS OF THE ALARM RECEIVER WHICH IS IN THE UPPER REAR ROOF BELOW THE CORTESY LAMP.
GOOD LUCK
REGARDS JORGE :)
I have a '96 155 2.0 TS and the original equipment alarm does require you to stand next to the rear door and point at the rear courtesy light.
mine's standard too, luckily i can use it from the 3rd floor of my work building hehehe
as people park and oven their car door 'blip blip' :D
Discussion Starter · #7 ·
My factory fit alarm works from 20 metres OK
The only time I had problems was when the battery contacts needed cleaning and then it didn't work at all
Thats a 96 super model
Mike
