M
meikdunj
·Guest
Not really a big deal but alarm does now not 'beep' when car is locked / unlocked with the remote, any one else had this?
I have had this happen, but only a couple of times. Usually I find if I unlock with the reomte, open and close the door, and relock with the remote, it's fine again. As mine is related to the doors being opened and closed again, I assume it must be a sensor or contact issue, but it doesn't play up often enough to be a hinderance. Sorry that I can't be of any more help.Not really a big deal but alarm does now not 'beep' when car is locked / unlocked with the remote, any one else had this?
Good point, iv'e had this occur once or twice also.If it's a sensor issue the alarm will arm normally but then beep
again to warn you that it has taken the sensor offline.
Basically, the standard alfa alarm can be set for the country it's used in.... In some country settings it beeps, in others not....Can the beeping noise be turned down or deactivated?
Ive never noticed a beepBasically, the standard alfa alarm can be set for the country it's used in.... In some country settings it beeps, in others not....
Actually, you can also change the 147's ...You can only change the 156's.
Boot open? or at least the sensor.Woah, whats this? My 156 makes one long tone, then beeps once more, what does this indicate?
My 156 also does one long beep followed closely by another beep. Always has done... just thought it was supposed to do that...... certainly no boot or doors open.Boot open? or at least the sensor.
