Hello,
After replace battery I can't turn off alarm.
Key wont working at all. I can open car using key, and is no problem with starting car.
Is there any way to turn this alarm off?
Regards,
Rob
C
:cool: i had the same problem open the key and the small metal strips that touch the battery were missin so bent them back slightly and replace battery and now all is good :)
if its not the battery check this out
http://www.alfaowner.com/Forum/alfa-145-and-146/118843-key-code.html
and one last thing are you sure the battery is the right side up ? i know its a stupid question but try it the other way its easy to miss the obvious
Thank you for your answer.
That was different problem.
Car battery wasn't in good condition after few minutes all back to normal.
Best regards,
Robert
