K
keithyboy
·Guest
I've finally reached a stage where I have to change my air filter and I've got a bolt problem. One came out fine but the other two are turning without coming out.
I'm guessing there's a metal insert in the housing that's come loose. Is there any way of dealing with it other than just lopping off the bolts with my grinder?
I plan to remove the box to sort it, do I need to remove anything other than the top hose in order to extract it?
n.b. the resonator box is long gone in favour of a V6 intake so I only need to pull that from underneath.
