1 - 2 of 2 Posts
· Registered
hi all
having trouble with my aircon it suddenly wasnt blowing cold anymore so went for a full cleanse and re gas after that it started blowing cooler now i'm back to blowing outside air temp again. my first thoughts are theres a leak somewhere but any other known issues would be appreciated?
thanks
· Registered
Clearly a leak in the system. They will need to pressure test and inspect thoroughly especially the lower hose going to the condenser which can get pulled out accidently. Failing that, a leak test with dye will be needed for slow or less obvious leaks.
1 - 2 of 2 Posts
