K
I'm breaking my 156 and a bloke is looking for a resistor which apparently lives under the passenger seat. It looks like the pic below but I can't find the little bugger under there.
Any ideas?
Mounted to the underside, front edge of the driver and passenger seat is a black, plastic box. You should see a yellow cable on ether side.
On one side of the box near the front you should see a circular bung/plug, prise this out and the tray will slide forward, inside is the connector you're looking for.
All the best
Pub
A resistor is only found if the passengers airbag
is broken, the resistor acts as if the sensor
pad still works i.e. It fools the ACU
And are these resistors to be had that are a simply plug in.. like the image above? If so, where can they be sourced?
Or are we talking about resistors like this...
..that have to be manually wired into the plug/socket?
All the best
Pub
