does yours actually have a passenger airbag?cant see it there either am I right in thinking im looking for a slot for my key so i can turn it off?
I have looked everywhere in the car and i cant seem to find it anywhere.
:lol:Good point David:thumbs:does yours actually have a passenger airbag?
As a mechanic i would NEVER recommend doing this, it is dangerous....If you do not have the deactivation key as described earlier, then you need to disassemble the airbag, 4 bolts inside the glove box, when you have pulled the airbag out disconnect the yellow connector and the end coming from the car (not the airbag end)is to be connected to the yellow dummy resistor in the bottom of the "hole" where the airbag was mounted, all this must be done with the ignition key out of ignition switch.
