1 - 13 of 13 Posts
· Registered
· Registered
I've got the free version of multiecuscan, not sure if it will reset the light but we can give it a go if you need to. :)
Yes, the free version will reset the light, as long as you have the correct cable to connect to the airbag module. Post 2004 cars will reset themselves once the fault has been fixed.
· Registered
tis funny, ive had my airbag light on for a couple of weeks now,and as I drove off the A1 to goto QSP to get the GT tested, I pulled over and thought I would try and jiggle the wires under the seat,and it worked!!!
passed the test with a few advisories.:thumbs:
· Registered
That's the usual culprit. It's a good idea to separate the connector, spray it with some electrical contact cleaner, reconnect it and secure the two halves of the connector with a cable tie, the problem won't arise again. Full instructions in the link I posted above...
· Registered
Hi Seamus thanks for the kind offer, where abouts are you and when would you like to try it.:thumbs:
I'm in Stakeford, just south of Ashington and I'm off work for the next five days. :D
Good stuff, passing your MOT I mean, not getting jiggy in the passenger seat. :thumbs:
· Registered
Failed! :mad::rant::mad:
After much frustration then a little research we realised that elm327 cables will not connect to airbag modules.
Schoolboy error!
Sorry mate.
Did you not read the link I posted to the sticky in the 'how to' part of this lounge?
You need a modified KKL lead or the correct adapter to connect to the airbag module.
Theres links in the sticky on where to get them.
1 - 13 of 13 Posts
