Hey
I need some help :)
I have the red airbag light on. "09 Passenger squib circuit value too high, Intermittent/present 240"
Tried clearing the error code with Multiecuscan. But it won't clear.
I tried all the tricks, cleaning connectors etc..
Does anyone know what it could be?
You don't say which tricks but here are a couple of possibilities:
Try cleaning the driver's side connector.
Clean the connector on the airbag ecu, it's on the tunnel by the pedals. Remember to disconnect the battery and wait a few minutes before disconnecting the ecu. You will need your radio code when you re-connect. (I'm sure you knew all that.)
I checked and cleaned the connectors under the seat, in the boot and on the airbag ECU.
Is there a connector for the passenger airbag somehwere around the glovebox?
Probelm solved. Took my chance and cleaned two big connectors under the airbag.. and yay... could finally delete the error.
:thumbup:
