1 - 10 of 10 Posts
Hi alfa gt 2005 airbag light was flickering intermitantly now on all time went under both seats pulled apart sprayed contact cleaner still lights up only happened recently owned car five years never a problem anywhere else cables join together due MOT soon has side curtain bags any other connectors to try or the control unit if so where is that ? thanks for any help.
Sometimes you need to clear the codes yourself with software. A simple repair of the fault and re connecting the battery does not always work to clear stored codes.
Best get the codes read anyway. Take a note of the codes/description. Clear the codes and see if they come back after 4 or 5 trips in the car.
Side curtain airbags cables are in the boot, the one on the driver's side used to give me issues. It's behind one of the trim panels.
You really need to plug the car into something to tell you exactly is giving you issues yes or you'll just be chasing shadows around all day long.
i looked on the passenger side could,nt see anything just 2 connectors along side the detonator..what a pain to take apart all boot lining..garage said passenger side somwher as car was in for mot so i need to get it fixed..
Not sure what car you have, but in my 156 there is a small plastic panel that is fixed with one screw in the boot. Behind that were the curtain airbag connectors for me. Even then the boot linings are pretty basic in sedans so they come apart easily. Hatches and wagons are finished to a slightly higher standard.
got codes read passenger airbag squib high value?? is that the seat or curtain does,nt really say whats most probable issue fix.
got codes read passenger airbag squib high value?? is that the seat or curtain doesn't really say what's most probable issue fix.
I would have thought that would be the main airbag in the dash.
I've had the same problem for years with my 147, and solved it simply by changing the plugs under the driver's seat. If you search you will find a tutorial with pictures I posted about 1 month ago.
ye im going to look into that might cut them off solder them all up seems to a resistance issue sometimes..
1 - 10 of 10 Posts
