posted 18.07.2003 20:27
pin 4&3 300/500 ohms (closed)
pin 2&4 10 ohms (closed)
should be smooth readings until it reads 200 ohms when open.
necessity is the mother of invention.
dont follow in other peoples footsteps...........be the one making them
Please Jimybob could you be more specific how to check if air-flow meter is working correctly.
I really don´t understand what you mean with "closed". :confused:
And another one, looking the motor in front of it which is first pin in the airflow meter? :confused:
Thanks in advance
Jorge
Discussion Starter #2
And I refer to the Air-Flow Meter and not the Intaken air temperature sensor (because it only has 2 pins ). :rolleyes:
J
jorge the information assumes you have the 'flap' type meter not the 'hotwire' version.
i wasnt sure which one you had.
Yes, I have the hotwire one, it´s ezactly like Daiblack´s diagram.
Thanks very much.
:p Jorge
