1 - 20 of 25 Posts
Apologies if this has been answered before but I have searched and not found an answer. My much loved 156 1.8 lusso has developed an air con fault and I'm hoping somebody can advise. When the external temparature drops below 3 degrees for whatever reason the air con will not come on. Once the external temp rises it works again fine!
The air con has worked fine before in cold weather so cannot understand why it is suddenly playing up. I use the air con to keep condensation free in the cold weather so it's a real pain!
Any advice most welcome.....
I press the air con button though and it does not light as if it is not working - when the external temp rises the button lights up again. Even when I press the demist and all 4 lights should light up it does not light so I'm thinking there is a problem somewhere espeiclly as it has worked in the past - apologies if I'm not explaining this well!
If the outside temp is below 3 degrees the aircon will not operate there is nothing wrong with your car unless you are not explaining the problem well
Yep, as said above... the aircon is not supposed to work below 3 degrees, and the light wouldn't and shouldn't come on. There's nothing wrong with your car unless you're struggling to get your point across.
In cold weather when I hit the demist should all 4 lights on the heating controls light? (Aircon / mono / front demist / rear demist) In the past they have but recently the air con light has stopped ligthing up (judging by condensation build up in the car the air con button not lighting up has meant the air con not working. The heater / temparature controls still works as I still get warm air coming through).
Only when the external temp goes above approx 3 degrees will the button light up and the air con work. (I know it works as I don't get a condensation build up)
Thanks for your paitence!
yep thats how it should be, turn the recirculator off if you still misting up:thumbs: though pressing demist will do that, just takes a little longer without the compressor;)
could always read the manual, says in there too;):D
Totally normal and your manual will confirm this:)
I asked this too. Thing is, I distinctly remember that it did work back in Feb 2009 last time it snowed. Aircon light lit up and compressor clutch engaged.
depends how cold it was;)
An odd 'feature' I must admit. No other aircon equipped car I have driven has this quirk. What is the reasoning behind it? COndensation freezing on/in pipes perhaps?? Or is it just 'one of those things, they all do that sir'
It's a design feature to prevent freezing the evaporator (the Air Con heat exchanger inside the heater box), imagine the inside of the heater box looking like your freezer iced up.
im pretty certain other cars do it too dont they:confused: safty feature to prevent screwing the compressor
My wife's MINI has the light on but Aircon does noot work ! Rang the dealership to see if it was "normal" . They said that this is the case as it stops ***** ringing up about their AC not working in low temps
Administrator
I think probably the other cars do, but they don't tell you like the Alfa does.
I'm sure all air-cons switch off in freezing temperatures, otherwise they would simply break.
no aircon system in cars works below -3 C not even in a Rolls !!
1 - 20 of 25 Posts
