Hi, all fellows, someone can tell me fow often needs to charge the air-conditioner R134a cooling liquid ?
I feel that the air con is not cooling enough.
My babe never received a charge of new gas grom factory.
And i think that the compressor also need a oil refill when it is recharged, is it correct ?
Jorge :confused:
Hi Jorge.
Iam am air con engineer to trade. You will probably find that your system has lost some of its refrigerant and this will be causing lack of cooling. there will probably be a small leak somewhere causing this and it will require specialist equipment to find the problem. do not be tempted to try and release the gas yourself as it is under high presure and can cause severe burns.
If the system just requires a top up due to refrigerant loss through the hose, a local air con mechanic will be able to do it for you for well under 100 pounds.
Hope this is of some help,
Colin. :rolleyes:
WELL I´M GOING TO CONTROL THE SYSTEM THE NEXT WEEK, BUT I WAS THINKING THAT IT WOULD COST NO MORE THAN 30 POUNDS = 1500 PESOS !
IT IS REALLY SAD !
REGARDS
JORGE eek!
