1 - 2 of 2 Posts
Hi'
My air bag warning light came on after I changed the speedometer bulbs, I read somewhere that it will come on if you disconnect speedometer
Does anyone have any suggestions on how to reset this light without paying a lot of money to car mechanic
No it does not come on if you discontect the speedo - it comes on if it has found a fault.
It depends on the age of your car pre-2005 (ish) you need to clear the error using one of the software systems - post this the light goes out when the error is no longer detected (although the error is in the ECU memory) .
Where are you as another forum user near by may have the software to clear the problem.
1 - 2 of 2 Posts
